elusive240 »
https://forums.nicoclub.com/elusive240-u9888.html
Mon Dec 25, 2006 4:35 pm
I just bought a 96 Nissan 240SX that has an auto transmission. It had some front passenger side damage that I fixed (LCA, strut, tie rod, etc.), but now that I can move the car I've found some issues with the transmission. When I push in the button on the side of the shifter to change gears it doesn't lock in certain gears. I can put it in park and drive just fine, but when I put it in neutral and reverse, I can just slap it into a different gear. It doesn't lock into the gear so I can't get the car into reverse. I've never messed with the transmission in a car before, so any help you could give me would be appreciated. Please don't tell me to just do the 5 speed swap because I have two other 240's that are 5 speed, and I intend on swapping this one to 5 speed as well, but not right now. I just want to get the car driveable. If there is any more information that you would need to help diagnose the problem, just let me know and I'll try and get for you. Thanks guys!
