240sx auto to 5-speed conversion help...
florida_jake
ok i know that there are a bunch of things needed to do but i got those done already... all i am wondering about is the wiring. i know that you can use tha auto harness for the swap but what needs to be done to it exactly? grey and whit wire need to be cut and spliced together right and those are the wires to the bottom right of the fuse box by the battery rightr.anything else need to be done?thanks and any help is greatly appreciated.
NISTECH
florida_jake
i have a s13 not a s14 sohc to be exact. i appologise but i thought i said that. my bad any other links that you got though?thanks
florida_jake
come on somebody please give me something to work with here... i really need this car running about a week ago and the wiring is the only thing i gots left to do. just give something to work with.thankss13...89-90
NISTECH
I will move this to 240 tech section. I just searched and couldnt come up with info either. good luck
florida_jake
thank you for looking though, and if anyone else can help please let me know.
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
ok, wiring is very simple for s13
when you take off the automatic harness, near the 4 plugs near the fuse box, there should be one plug that is hanging. it will have two wires (i think white and black) coming out of it on the trans harness side
cut that plug off of the automatic harness, and just jumper those wires together. thats all there is to it. it will start up after that (assuming you have done everything else right)
what it does is fake the car into thinking the clutch is pressed down all the time.. so be sure not to start your car in gear, cause there will be no clutch saftey lock. not sure about the reverse lights since im not going to even mess with them.
florida_jake
SHIFTrl240 wrote:when you take off the automatic harness, near the 4 plugs near the fuse box, there should be one plug that is hanging. it will have two wires (i think white and black) coming out of it on the trans harness side
you say when i take off the auto harness. i did not know that i would have to take off the harness. which harness are you talking about? the one connected to the fuse box oor the one on the transmission... please specify, because i am retarded thanks man.
SHIFTrl240
you have to disconnect the auto harness from the plugs at the fuse box to get the trans out, when you do this find that plug and cut it off.... thats the easies way
make sure to leave enough wire on it though
BoyWonder
Car: '93 Nissan 240SX S13 Convertible (reclaimed... wootles)
Mine was underneath the fusebox - should be the only 2 prong plug that goes to the auto transmission. All you have to do is cut the plug on the lower harness side, and splice the 2 wires together. If I remember correctly, the wires are white/red and black. I can try and get a pic later if you need it.
Hijacker
Car: '92 240sx Convertible
'94 F-150
for hooking up the reverse lights:
find the second plug next to the passenger side fuse box. It's called the inhibitor switch. you'll have to cut the green/blue wire and the green/white wire from the plug and splice some wire from those two down to the reverse gear sensor switch. It doesn't matter which wires you splice. As long as the green/blue goes to one wire on the switch and the green/white goes to the other switch wire.
tonynalli
where in florida do you liive. i live in alachua and i did my 240's conversion. i would be more then happy to help you if it is not to far away from where i live. or i can email you the steps that i went through
NISTECH
tonynalli wrote:where in florida do you liive. i live in alachua and i did my 240's conversion. i would be more then happy to help you if it is not to far away from where i live. or i can email you the steps that i went through
If you have an S13 you did the conversion on, do a write up on it. We could then make it an artical in the nissan article section. This would help other immensely in the future.
SHIFTrl240
actually, its about the same as the s14 wrietup, but you don't have to do all of the steps like hooking up the 4th and 5th gear sensors etc. also don't need an ecu if you don't mind the wierd auto idle.
florida_jake
i live in Deltona Florida. its about 45 min east of orlando on I-4. Past Sanford if you everr drive down that way. anyways it would be great to get a hand on the swap man. let me know if you can help.
BoyWonder
I agree with Shift - really don't need a seperate writeup for the S13, just to include a seperate S14/S13 wiring section. Everything else is the same.
Edit: Who do I have to talk to to get this added? I can do the write-up (I'll be sure to credit you, Bart :D) for the addition.
NISTECH
http://www.nissaninfiniticlub....68158
BoyWonder
Looks like I was beaten to it. As long as it gets done, though.
