pj »
https://forums.nicoclub.com/pj-u25266.html
Tue Sep 14, 2010 9:54 am
geez bro, check the tech section. this site is like an immense grimoir of nissan everythingisms.
imma help you a little to keep me from e-beating you.
ok,- look for rust under the car, frame rails etc. also check the wheel wells, engine bay for bubbles or the beginnings of rust. you really have to look, i was fooled before.
-if you cant choose between s13/s14 it doesnt matter, s13 type parts are easier to find used and it is very argueable which is better. 2 people will tell you 2 diff things. its personal preference.
-the s-chassis are great cras, they look good, they handle well, they have an extensive aftermarket and respond well to modification. ther are lots of motor choices for swaps, unlimited suspension parts from tons of companies in all price ranges, large engine bay, and are fairly easy to work on.
-most of the people here have theyre s car as a daily, some even drive heavily modified cras daily, usually the cali guys have the crazy low s***. but you can find examples of wild dailys anywhere. if they do it so can you.
-the big difference between the 89-90 to the 91and up s13 here in america is the motor, the early or zenki models have a sohc 2.4...the newer have dohc 2.4 both are KA24. KA24Ebeing the sohc, KA24DE being the dohc. nearly everything else is the same, the front ends will interchange, no welding needed.
-im pretty sure power options came on all models, so did non power windows etc. i prefer non power equip. but i have never owned one with no power options as far as windows mirrors etc.
-the performance between the 2 is about 10 hp/tq...there are pros and cons to both but most prefer the doch 91+
as far as buying a lemon? drive it check it out top to bottom, and feel the car, turn the radio off listen for noises, feel the clutch engage, feel for vibrations that seem out of place...its a mix of common sense and experience, reading posts here will help alot, as well as the tech section so i suggest you get to checkin it all out. and luck helps as well when buying a s chasis haha
