240sxmech wrote:first things first you need to pull the injector rail up with the injectors . . .
Thanks, 240sxmech You are absolutely right. The new mechanic I saw yesterday said that would be one of the first things he would do.
Unfortunately, pullin the fuel rail, or even pulling the valve cover off the engine are not within my mechanical skills at this time.
I bet you a hundred dollars the fluid is coolant running ou tof your exhuast because like you said when it was running it had white smoke that is coolant mixxing in your combustion chamber .blown head gasket.
240sxmech, the coolant has not gone down as might be expected, but I think I can check for a blown head gasket, and that is one think I will do. I don't think so, though...
See update below
I pulled FI #1 because it was the last one of two FIs I had recently replaced.
This was pulled a week ago - FI #1 was missing its pintle cap. The pintle cap probably got ingested. I bought a new FI and it sits on my workbench, ready for installation.
I took a piece of fabric and stuck it down the empty FI #1 hole.
The small piece of fabric came back SATURATED with gasoline!!!
This engine was not run or even turned over in the past month!! Only last week did I put a fresh battery in it to prove that the starter was bad. This fuel got down (where ever 'down' is) there testing a new battery, but not turning the over!!
((The pictures are small sized.))
The cloth is FIRMLY attached to this piece of hanger wire..
Now it is out of the FI hole, shown with a clean piece of blue towel paper.
This is how much was on the fabric. The fabric was dripping fuel.
The gas completely saturated the paper towel.
Next step is to pull the spark plug from cylinder #1 and see if gas is down the cylinder.
Anybody taking bets?!?!?! ((The compression is normally 182 - 187psi, so it is possible))
((From the experience with removing FI #1 when it was inoperative, I will not even consider pulling the two older FIs. FI#2 may come out easily, though..))
Modified by honeybus at 8:46 AM 7/27/2007
