240SX-89 - Fuel Pump Problem
Jacques MArcotte
Car: Mechanics. I am restorating an Austin Healy 1963.
I have an intermittent problem with my car. Again today it does not start.The ignition is OK but there is no power to the fuel pump. I suspect afaulty relay. Since I do not have the repair manual with the wiring diagram,I cannot locate any relay or component that might cause this problem.The fuel pump operates correctly when I connect it directly to a battery. Itdoes not start even when I try it while the pump is connected to the otherbattery.
I have connected a test light to the two terminals at the fuel pump andattached the light to the antenna to view it while I try to test differentcomponents and relays under the dash and under the hood. So far nothing lights-up.
Thanks for your help.:help
drjohn
The fuel pump relay is the second green relay from the back of the relay box on the battery side.Check the fuses in the relay box under the hood the fuel pump fuse is in there.
