240SX 5-SPEED Swap (DVD) Over 2 HOURS
http://store.driftingshop.com/245spswd.html
240SX 5 Speed Swap Guide
Covers all the basics and even goes further, with the 5 speed brake booster install, plus more!Covers the s13 & s14 chassis - as well as pulling the motor/transmission as one and then just pulling the transmission from under the car. So you will see it done both ways.
Completely explain the wiring on the s13 & s14 as well as a “how to” on soldering wire.
This video covers it all including motor/transmission maintenance – bolt/nut sizes and part #s – upgrades - oil seals – gaskets – new parts – tricks and tips etc…
It also shows what is compatible between the s13-s14 and auto-5 speed. It goes in-depth to show how and why the parts work and will not work.
This DVD is 2-1/2+HOURS LONG. – Using the newest DVD technology - Double Layer DVDs 8.5gb.
5 Speed Swap DVD Chapter Layout
CH 1 - StartCH 2 – Getting everything ready to pull the motorCH 3 – Draining & removing the radiatorCH 4 – Removing the exhaust manifoldCH 5 – Draining & removing power steeringCH 6 – Removing throttle & cruise control cablesCH 7 – Disconnecting wiring harnessCH 8 – Auto transmission removal in & out of carCH 9 – Auto transmission shifter linkage removal under carCH 10 – Auto transmission shifter linkage removal out of carCH 11 – Auto transmission speed sensor & O2 sensor removalCH 12 – Removing the driveshaft under the carCH 13 – Removing the driveshaft out of the carCH 14 – Removing the interior stuffCH 15 – Auto transmission coolant lines removal under carCH 16 – Auto transmission coolant lines removal out of carCH 17 - Auto transmission mount & cross member removal under carCH 18 – Auto transmission mount & cross member removal out of carCH 19 – Auto transmission gusset removal under carCH 20 – Auto transmission crank angle sensor removal out of carCH 21 – Auto transmission bell housing bolts removal under carCH 22 – Auto trany bell housing bolts removal out of the carCH 23 – Auto transmission removal out of the carCH 24 – Auto transmission removal under the carCH 25 – Auto transmission flywheel & torque converter removalCH 26 – A/C compressor removalCH 27 – Bolting up the engine lift in the correct spotsCH 28 – Pull motor/transmission clipCH 29 – Motor maintenanceCH 30 – Clutch & flywheel installCH 31- Pedals and brake booster install and removalCH 32 – s13 clutch pedal in a s14 and vise versaCH 33 – Auto brake booster removalCH 34 – Front seat removalCH 35 – Under DashCH 36 – Auto brake pedal removalCH 37 – Auto brake booster removalCH 38 – Auto brake pedal pin removalCH 39 – Auto brake pedal removal cont.CH 40 – Clutch master cylinder installCH 41 – Brake & clutch pedal installs out of the carCH 42 – 5 speed brake booster installCH 43 – Pedal installs under dashCH 44 – Clutch master cylinderCH 45 – Clutch slave cylinderCH 46 – 5 speed swap wiringCH 47 – Under dash wiringCH 48 – Under dash wiring out of carCH 49 – Wiring the pedals I the carCH 50 – Engine bay wiring behind fuse boxCH 51 – Removing the ECUCH 52 – ECU wiringCH 53 – 5th & neutral pos. switches wiringCH 54 – ECU talkCH 55 – 5th & neutral pos. switches out of carCH 56 – Installing ECUCH 57 – s13 5 speed swap wiring convertibles tooCH 58 – 5 speed transmission overviewCH 59 – 5 speed transmission shift linkage woesCH 60 – Prepping the trannyCH 61 – Throw out bearingCH 62 – transmission prepping cont.CH 63 – 5 speed & auto speed sensor differencesCH 64 – Installing motor/transmission back into carCH 65 – Installing motor/transmission into car clipCH 66 – s13 & s14 transmission cross member differencesCH 67 – s14 AT & MT driveshaft differencesCH 68 – s13 & s14 5 speed driveshaft differencesCH 69 – Installing driveshaft & transmission cross memberCH 70 – Installing radiator fan & shroudCH 71 – Installing transmission in & out of carCH 72 – Installing transmission from under the carCH 73 – Bell housing bolt sizes & part #sCH 74 – s13 & s14 AT & MT gusset differencesCH 75 – Starter motor & crank angle sensor installCH 76 – Installing short shifter & transmission fliudCH 77 - transmission fluidCH 78 – Install everything left offCH 79 – Power steering fluid refilling procedure
