skydragoness »
https://forums.nicoclub.com/skydragoness-u193.html
Wed Jul 27, 2005 5:07 pm
Hmm, is the 300zx totalled? Because if its not...240sx brakes will not work, wrong bolt pattern and too weak for a 3000lb+ car as was already said.
As far as putting the Z brakes on the car, you may as well suck-it-up and like the Z rims if you plan on using all 4 brakes/hubs. Reason I say this is because the Z calipers will not clear the teardrop S13 rims anyway. Besides, with a 5-lug setup on a 240 you will have a plethora of rims to choose from. It's extremely hard to find good rims with a good offset for a 4-lug 240sx. As far as the brake lines, I recommend going to SPLparts.com or PDM-Racing and get the brake line kits that set up the S13 for 300zx calipers. The 240sx uses a banjo-fitting, and the 300zx uses a IF flare fitting. Besides, stainless lines are great for getting rid of that mushy pedal feeling. Also, if you are going with all 4 Z brakes, you will have to modify the ebrake cable to work with the 240sx, AND also buy the master cylinder off your friend's Z because you WILL need it. The brakes are massive for the 240sx and the tiny stock m/c does not have enough pressure compensate. If your friend's car isn't totalled and he plans on driving it, there's no way you guys can just 'swap'
