Eikon »
https://forums.nicoclub.com/eikon-u15727.html
Wed Aug 29, 2007 10:11 am
I'm sure others will chime in as well...
I'm no SR expert, but from what I understand, the 6 spd trans from the S15 Silvia is not worth spending the extra money on. An S15 motorset is very expensive (much more than the S13 or S14 motors). While the engine is of course newer, and likely in better shape, it's not really worth the extra money as the hp bump is small. Also, the 6 spd trans is not as strong as the 5 spd trans.
So, to answer your questions (as best I can).. Yes it is possible to swap in a 6spd S15 trans with that motor into a 240sx. S15 motorsets are usually over $3k vs. $2k for the others.Sure.. it's a good swap.. but maybe not as good a value as the S13 or S14 SR20 or RB20 or CA18, etc...
