240s13 to rb20det swap
memphis240
Car: 95 240sx s14
hellow, i need some advice. having trouble geting car to start. it turns over, its pumping fuel, new plugs, got power to coils, got power at injectors. have swaped out ecu, and ignitor. ecu has power. relays have power ect..... any advice is much appreceated. also the car did run befor, what happened was the innercooler piping came loose wile it was runnung, the motor started diying and shut off. has not run sence. please help
Modified by memphis240 at 11:41 AM 5/25/2009
Modified by memphis240 at 11:45 AM 5/25/2009
Shift n Drift
Car: 240sx
power fc
Sent: 30 Mar 2012 19:12
To: Shift n Drift
hi do you still have the apexi power fc. if so is it for a dejetro or what. are their any maps on it or is it wipped. thanks
hey you have your PM's disabled, go to user control panel and enable them and we'll talk
