240mm clutch
newbe40
Car: svt focus 95 240sx se
anyone try using a 240mm clutch on a 240sx flywheel stock clutch is 225mm.The machine shop I use said that the flywheel from a 240sx that uses the 225mm clucth could be machined to use the 240mm clutch 280zx turbo,z2+2 or truck anyone done this and if so how about some details,like how much power will this handle ?I looked at a truck flywheel with the 240mm clutch and is very close to the same as a 240sx flywheel.
TurboKA37
yes, it has been done. if you do a search there was a very good thread explaining what was needed to make it work. Im not sure if the search function has been working properly lately tho
TurboKA37
heres one of the good threads:zerothread?id=50271there are a bunch more threads on this subject if you type in "240mm clutch" and search recent archived
nonchalant rage
Car: s12
also known as the white bunny special
