240dx Short Block Rebuild. With Pixxxx
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Awesome man, well done!
Gabes13
Car: rb20det s13
240dx wrote:I broke up with her about 3 weeks ago.We were going out for about 3 years.im 18 and didnt want such a committed relationshipBesides we were drifting apart and didn't connect like we used to.She was beautiful through anybody's eyes and she could whooop some a**.But it got to the point were that didn't matter anymore.
jk
240dx
Car: '97 Nissan 240SX LE
Alright. I am continuing were I left off. Thank for all your support btw.I ordered the OSK timing chain from FRsport.I also ordered the OEM Oil Pump Valve Set from Nissan. Here is the OSK timing chain kit.I know when it comes to timing componants it should be OEM.But this was more suitable for my price range. I did much researchand found the OSK kit to be quite reliable.
Here is the Oil Pump Valve Set from Nissan.According to the FSM these pieces should be replaced.
I made #1 piston Top Dead Center.OSK kit came with 2 new bolts for the chain guide.torqued them down to ...
toqued in chain tensioner and opposite guide and used the head sprocket to hold the chain up. +Made sure yellow marks are alighned. In the meantime I used break cleaner and Simple Green to clean up the front cover.Scraped and cleaned the machined mating surface of the cover.
I removed the pump case. Becareful the screws tend to strip easily so make sure you use the correct sizescrewdriver. I removed the pump gears and cleaned them.I measured the gaps between my original pump gears and they're good.It's quite interesting the way the pump works, it's so simple. Here is the OEM valve set in the order it goes in. Primed the pump with new conventional oil.and torqued the case to the front cover assembly.Replaced the Front Main with the provided OSK seal, I used fresh motor oil to easily pop it in.
I used a Liquid Gasket bead around the front cover and used a provided O-Ring as indicated in the FSM. I alighned the oil pump inner gear with it's mating partner on the crankshaft I carfully pushedthe front cover into position. I toqued the front cover downusing the FSM reference.
I have my cylinder head.nothing special done. It was cleaned and new valve stem seal replaced.I had the machine shop do it so I have no pictures.
PhopsonNY
Car: 1989 Nissan 240SX
Very useful thread... keep it up.
Excellent work
Legion76
Car: 95 Zenki, 99 Ram 1500
When I decide to rebuild my KA, I'll definitely use this as a reference. Great job so far.
ghx407
Car: 1993 240SX KA-T
Excellent write up!
Waiting for more...
Lonismos14
Car: 1995 Nissan 240sx, 1999 Chevy Hoe, 1996 Saturn Sl2
Almost there
B.C. Ftw you know what i mean you live there.
240dx
Just thought id let everybody know the engine purs. no major issues what so ever.
its been about 1000km so far :) my first engine rebuild! :biggrin:
KoopaTroopa
Car: 1991 black hatch
Congrats about the successful first build! I'll probably be doing exactly this within the month, how much has all of this costed you so far?
troskinatior
Car: A Two Tone Piggy Coupe
Thats great man! How much car knewleadge do you think a person has to have to rebuild a ka? and lastly can you post the rest of your build?
elchoccolatte
Car: 2K3 2.5 SL Altima, 91 Nissan 240 Sx Se
Good Work
240dx
Still runs strong with noo problems :yesnod
