240 wont start has blue spark, gas, and timing okay please help
harleydavidsonboy
Car: 1989 240 sx
I have new plugs wires, cap, rotor, plus have fuel. What more can the problem be? The spark is a nice blue color! I cant figure this out. please help
240DRFT
it could be alot of things...try to diagnose the problem before u start buying a whole bunch of new parts
InsanityInc
try giving it gas while trying to start it.
harleydavidsonboy
Car: 1989 240 sx
I have tried giving it gas. Plus sprayin starter fluid in the spak plug hole and then trying to start it and it still wont start. What happened was when driving the car it started to chug and then the motor just cut out. Has not started since. was driving great before. The rotor turns and the lifters move when trying to start the car. What other things can it be?
InsanityInc
are you sure the timing is right? Use a timing light to check it while cranking the engine.
180fan
Car: 89 fastback
are the plugs in the right spot on the distributor cap?
harleydavidsonboy
Car: 1989 240 sx
I have called my friend with a timming light so going to try that later today. Yes the plugs are in the right order. I took one off at a time and replaced them. anyone have other ideasthanks
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
make sure u check for TDC and make sure u adjust the rotor button to plug #1 and it will fire right up
