240 wont shift
ls1240
Car: 1990 240sx hatch
hey i got a 90 hatch with sohc motor and a transmissioin A/T that came from an 91 240 and had to extend some wires that were cut from a removal but all wires are saudered and taped up so i need to know this when im driving like from a stop it wont shift out from first to second and on but if i let off the throttle itll shift then i get back on to it and off and on does anyone have any ideas to why this could be happening any suggestions will help i will recheck my saudering job
thank you for any suggestions
allenms240
Car: 1991 Nissan 240SX
There is a plug by the fuse box under the hood, on the passenger side. There are two plugs. Unplug the top one and see if that fixes it. It is the transmission rev sensor (I think that's what it is called). It sometimes go out. When you unplug that, the shifting will default on the speedometer. I had to do this to the GF's vert.
ls1240
ok thanks a lot man!! ill go try that now
allenms240
Let me know how it goes!
ViolatoR
My A/T won't shift out of first if I drive too slow, like ~23mph for too long, or start slow from a stop. If I can't get it to shift by slowing down and speeding back up or revving hard, I'll have to stop and turn the car off and back on. Rarely happens now, though sometimes in the past it happened a lot. Someone said it was because the car had been in an accident in the past, I guess he was thinking it was a transmission/gear problem(?). Once my car is running again I'll have to try pulling that plug. I did replace my Throttle Position Sensor (TPS) but that didn't do anything.
