240 won't reb above 5000 rpm
jhons240sx
Car: 93 240sx coupe
my 93 coupe won't rev up above 5 thousand rpmevery thing worlks in the car no check engine light is on everytime i get to 5000 rpms if feels as if it was redlining if any body can help me please i know that the power is there i just don't know how to unleash it.
PMan_S13
Car: Building car -> breaking car -> fixing car -> start over
does it bounce off like how rev limiter does? Like rrrRRRdaarrRRRdaarrrRRRdaa
You might have a problem with your 5th gear sensor. The ecu is designed to govern the top speed of the car. One way is when it gets to ~5000 rpms in 5th gear it will cut the fuel. Just like a rev limiter.
If you're sensor got stuck in 5th or something, it might think you are always in 5th. When it gets to about 5000 rpms the ecu might be thinking you are closing in on 120mph.
It does this in nuetral as well. This govenor is only gear speed related. It doesn;t really know how fast you're going, just at what rpm and what gear it is.
You can unplug that sensor and see if it will rev any higher.
jhons240sx
Car: 93 240sx coupe
Thanks a lot and yes you are correct it feels just like a rev limiterone thing though i don't know where the sensor is if you could tell me i would really approciated thanks
Chingon
Car: 1991 and 1992 hatchbacks
I thought all the ka's did this...
just kidding... Is your maf plugged in and in working order?
