I have a 92 240 sx that started missing on the number 1 cylinder the other day. I could pull the spark plug wire on the 1 cylinder and the car ran the same as if hooked up. I also pulled the number 1 injector plug and no change either.
The car would at least run on three cylinders
So like an idiot I pulled the number one injector and cleaned it with some carb spray. put it back in and it ran as normal for ten minutes and then back to the misfire
So i pulled it again and soaked it in gumout over nite
Installed it today and the car would not turn over at first and when it did it ran awful...backfired with blue smoke coming out of the exhaust...stalled when I backed off to idle
So i replaced that injector with one from a junkyard. Car won't start. Installed a second jy injector, car won't start, back to the original injector, car wont start
Could I have air trapped in the fuel rail
I replaced the gas filter. I checked each plug and have spark. I also checked the timing and its right on the money
Any ideas ?
