240 sx starts, idles, shakes, dies
dancad
Our 240 SX will start, idle for about 15 - 20 seconds, start to shake, the dies
Any ideas
240FeVeR
Car: 1992 240sx Coupe!
lots of ideas. What have u done so far to narrow the problem down (so someone doesn't waste their time suggesting it to u again). Have u checked your timing?
dancad
We checked the timing and are ok there
We checked the fault codes and came up with 34 - knock sensor
Would that cause the car to stall
yoesh1
Car: 1992 s13 fastback
My s13 ['92] #3 fuel injector was not firing correctly, or possibly at all, and it made my car shake like crazy. My rpms at idle were also low, which makes me think it may have been close to stalling out, though it never did [well maybe once or twice].
dropped240
Car: 1991 240sx coupe turbo
this'll sounds super stupid but check your maf. my air filter was off by about 2 centimeters and i had teh same exact issues. just a thought. figured i'd share
dancad
I had pulled the air filter and just put one back in yet did not close the cover
Will try that and see what happens
Thanks
240FeVeR
Your car doesn't need an air filter to run, so the air filter is not the problem. If someone someone fixed their filter and their car ran fine again i'm sure it was the wiring to the maf that was messed up and all the moving around to install a new air filter masked the problem.
clear the codes and restart engine. When the engine is going to die open the throttle a little, not much just a little to keep it running. see if you can keep it going until it warms up. After the car is fully warmed up see if the symptoms are still present.
jinjinweiwei
Car: 95 240SX
ALways check your MAF first. go by a used one now!
dancad
I figured it out
I pulled the MAF and a leaf was on the wires
removed the leaf and she fired right up
THANKS for all the help
yoesh1
MAF = mass air flow meter?
sorry :P
