240 sx revving but not accelerating?
airleprekan
Car: 1992 240sx auto
Hey i have a 1992 240 sx auto. And lately its been acting like its in neutral spurratically in stop and go traffic and will revv but not accelerate. I checked the transmission fluid. I was convinced it had to do with exhaust backfire and i completely overhauled the whole exhaust system and i fixed oil pan leaks. Anyone have any suggestions?
Klits562
Car: white s13 coupe
how many miles do you have? I would say its probably your transmition i dont know alot about autos but i would say its either one of the several wet clutches in the trans or the torque converter either way im betting on your transmission causing this.
Does it free rev(fast like its in neutral?)
or does it rev slow like its in gear but you just dont go anywere?
airleprekan
it free revs like im in neutral
airleprekan
180,000 miles on it too
and yea i was afraid it would be in the transmission
comatoseculture
Car: 1990 240SX coupe. Currently running on Megasquirt.
Worn out bands and clutches sounds like.
CA18Magic
Car: 1992 240sx Coupe/ 2007 Subaru WRX STi
comatoseculture wrote:Worn out bands and clutches sounds like.
Sorry, but torque converters do not have the same type clutches... They are mainly fluid driven. There is a pump in your torque converter, and when it stops... well, there you go. No power transfered to the transmission.
http://www.google.com/imgres?imgurl=htt ... s%3Disch:1
comatoseculture
wow. I do realize the post is wrong, but I didn't imply the torque converter had bands/clutches. I don't know why I was off base like that tho. Regardless, you sir are correct.
dgms240
Car: '90 s13 hatch ka24det
agreed... torque converter is bad.
240s-sex
Car: 1995 240sx se
actually auto transmissions do have clutches :chuckle: not like what you think of on a manual trans, more of the way a limited slip differential has clutches, as in mutible frictions surfaces to smoothly transfer power
but back to the question at hand, did you check your trans fluid with the car running and in park? def souunds like a slipping trans
krash
As they said, torque converter. Do a 5 speed swap.
