Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Sat Nov 15, 2008 5:43 pm
Well, did he say what kind of LSD? 2 ways usually click when you make slow turns. Can you elaborate on "loud". Everyone have a different definition when it comes to "loud". If the car pulls to the left, do you mean your car is "Fish Tailing"? If it is, then yes, you have a LSD, then again, it could also just be a welded diff and he consider it a "LSD". Fish tailing is when your rear end loses traction because both wheels are turning faster then the car is moving causing your rear end to sway to one side or if you counter steer, it'll sway the other way hence the term "Fish Tailing". The reason why a car without a LSD does not fish tail is because only one wheel is spinning faster then the car and the other side is sill keeping the car stable along with the two front tires.
