240 sx problems staying on
ammons_eli
Car: 1993 nissian 240sx
ill ride in my car and all of a sudden at a red lite ill watch my cars rpms drop to 0
93240cooool
Car: 1993 240sx
isnt that every 240??
o_O
SupahTyTeTwoFowty_y0
Car: at least 15 but no more than 2
someone must have hacked your account and made a thread with a stupid title pretending to be you.
Nesquick
Car: Rb26 Kouki Silvia
does the car shut off when it hits 0 or does the car still run???
if it still runs, your wiring on your cluster is messed up.
if it dies, check for vacuum leaks, check your mafs, etc. lots of info out there about these cars not runnin
ectomorph
Car: 1990 240sx SE
something like that happened to me too. i replaced my MAF sensor and it fixed the problem. try replacing the MAF it might work.
AZ89two4Tsx
Sounds like a bad engine.
Gabes13
Car: rb20det s13
hows your battery?
AZ89two4Tsx
^ What would that have to do with the car while it's running?
**Last comment was a joke.**
Gabes13
Car: rb20det s13
If I'm not mistaken, a bad battery wont fully charge even if the alternator is in good condition. So when you press your brakes, let's say at a stop light, your tail lights use up all your sweet battery juice and the car dies.
Yeah that's probably not his problem but w/e.
Plus, before you go checking any sensors or electronics, you have to check if the battery/connectors is any good in the first place.
