240 SX owner From LONG ISLAND that needs HELP ASAP..
ChrisEspo83
Car: 1990 nissan 240sx
Hi guys I could use some help ASAP... I’m stuck wit a problem that won't go away. I bought the car and it has a hesitation when u hit the throttle kinda like a hickup or a spudder. I tried changing the fuel filter and nothing. I tried using that stuff called Sea Foam that didn’t help. Now I’m in the process of removing the EGR system. But I’m having trouble getting all the lines behind the valve cover. The lines closest to the fire wall. I don't know which ones to take off because cuz there are so many. What I am asking is if there is anyone from long island that has done this mod completely that could help me out. I could really use the help... im hoping this will stop the problems wit the engine. Plus I need help installing the aftermarket altima electric fan into the 240. So if you guys could help me out I would appreciate it..
Thankyou\Chris
DJButton
Car: 2010 Nissan 240sx
Moved to a more appropriate forum.
