240 sx engine swap question
areda32
Car: Trying to build a 240 sx beast
Im doing a sr20det swap with a vvl head in the existing car there's a ka24 with an automatic im also making it a manual..my question is when i remove the engine and drop in the sr is the harnesd and istallation the same process for the most part? All help is appreciated..thanks
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Harness will need some modification. You will need manual parts engine will bolt right in, trans will with correct manual parts. Do some searching, your answer has been said over and over.
95zenki man
Motor will bolt right in, trans will as long as you have a manual brace. All the wiring is pretty straight forward aswell just plug everything in and make a jumper for the gray plug by the bat, you will need to splice a few wires for the dash harness (cant seem to find a link to the thread for that) should be 6 or 7 wires for all your gauges. Be sure to do the clutch peddle and have as much as possible hooked up on the sr before putting it in the car to save some time.
When i did my swap i had everything already on the motor before dropping it in. All of 2 hours later she fired right up first try. Keep it simple and take the time to do as much prep as possible. Trust and belive it will save you hours of headaches later.
