I have a 1989 240 SX Coupe and have two problems, 1) The cruise control does not work with the lights on (but the green light stays on as if it was working
) 2) The left (drivers) side headlight only works on low beam ( even when replaced, but hitting it can bring it on on high
) 3) The center brake light ( behind the rear wind shield) housing was melted at the place the lights will be ( I got the car like that, but I saw an article about that problem, something about the wiring being incorrect on the main stop lights
they work fine
) Any info will be greatly appreciated.
Javier
