240 scraping question
shift0246
Car: nissan 240sx
whats up i have a 91 240sx with super hicas everytime i drift and get sidewayz i hear this loud sraping diiging into the ground noise from inside of my car but i know its sumthing on the outside i get 75% done with the drift and all i hear is crshsssshshshshshssshh hitting the ground i checked like 50 times under my car to see what it is and cant find no scratch marks or anything like that im thinkin its the hicas but not sure need help asap!!!!
racin-type
Car: cars
this phenomenom has also happened to me. its like you said 75% done with drift or most likely spin out and bam this noise.
I'm not sure either, me and my friend just stop spinning out or didn't care. and our cars were stock height so nothing coulda touched the ground.
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
What you are most likely hearing is tire noise. This noise is created when the rear tires are trying to turn(because of the hicas) and you are sliding(putting extra load on the tire going sideways as opposed to straight). You are basically just fighting with the tire. I also had this problem before my swap, the solution, get more power. It no longer does it and my hicas still works.
Nameless EJ6
Car: What the **** do you think.
YEa, more power + LSD.
justmerging
If he has hicas he has an lsd. They came stock with vlsd.
Axel Grungy
Car: 2001 G20 5spd
hicas isnt good for drifting...
justmerging
If you have a decent amount of power hicas doesn't even make a difference.
Nameless EJ6
justmerging wrote:If you have a decent amount of power hicas doesn't even make a difference.
it'll make a difference to someone who likes to attend drift events regularly. Im sure any professional would also say that they disaprove of hicas for drifting.
summit battle
Car: rps13/fc3s
was the sound in the front or rear? could the sound be the fender hitting the tire? or the tire hitting the inner fender liner? i have had this happen to me. when it comes to the hicas issue. make do with what you have. i am sure the the hicas isnt going to help your drift at all but its not like its gonna make it imposible to slide the car. but hell i am a noob so you dont have to vallue my opinion.
