Napa??? Really? GTFO!Future_gohan wrote:go to napa and buy a single wire o2 sensor. put it in. bet your car runs amazing. :]
(napa has them cheaper then advance btw)
not once its warmed up it won't. My timing was off so bad it made it run so rich it corroded and destroyed the 02 sensor, it wouldn't start once it warmed up.VietGQ wrote:it will still start even wif a bad 02
I have a walbro 255lph fuel pump, would that cause me to run rich? If so then i will check the O2 sensor (or if it doesn't start once warmed up again). I do know that my dist. was bad though, it looked bad.Future_gohan wrote:not once its warmed up it won't. My timing was off so bad it made it run so rich it corroded and destroyed the 02 sensor, it wouldn't start once it warmed up.
So yes, i honestly think its the o2 sensor.
thanks, I guess they drop a little bit but not more then 10-20 rpms. I think I am fine now, I was just curious.Ilvemynissan wrote:This is to do with your thread abt your brakes. Your RPMs should drop if you press the brakes rapidly, even if there's nothing wrong.
