moso »
https://forums.nicoclub.com/moso-u137641.html
Sun Jan 01, 2012 12:11 am
in that case i would.... check the ecu, see if its stock. generally look over the wiring for any "modifications". pull the fuel rail, with injectors and fuel lines attached and key on to see if your injectors are leaking, then crank to check spray pattern (bring a towel and fire extinguisher, injectors are made to make fuel burn easily). change the oil, change the oil, change the oil, fuel in oil is very bad. check the ecu for codes following the procedure outlined in the fsm and go from there.
