240 Running Hot? Help!
oo-gonzo
Car: 1990 Nissan 240 sx
I just bought a new project car! A 1990 240 sx. Car runs hot and will actually boil over within about 6 miles of easy driving. It runs hot after just sitting in the driveway for a few minutes. Fan clutch is slipping a little. No fluids coming out from the block. It has a new radiator, Water Pump and Thermostat. I think that the head is bad, but I don't know enough about nissan motors to tell. Any ideas or recommendations. Thanks for any help!
dickie
Car: Killer Turtle
if your fan clutch is slipping, replace it. you sure your thermostat is in correctly? flush the system before replacing with new coolant? you can get a pressure tester to test the system for leaks. if the "head is bad" you will be able to notice it.
Vegascorbin
Car: 1990 240sx dirt track race car
An answer from out in Left Field.I had a Cavalir that would overheat in no time flat and it was the cat converter pluged up. Of course I also noticed lack of power etc. If all else checks out you may want to check the Cat. Converter.
