240 rear sub frame?
240sxGT
Car: 97 Nissan 240SX SE
98 Nissan Maxima SE
93 Subaru Imprezza
Hey guys will a 95 rear sub frame fit in a 97, and are they exactly the same? Use all the suspension pieces for my 97? Reason is there is one in a junk yard for cheap, I want to clean it up and install everything on it so then I can just bolt up to my car...less downtime!!
nismofly
Car: 89 Nissan 240SX Hatch
i dont see any reason why it wouldnt
the difference isnt in the chassis, their both s14's, just the front end and maybe a few interior tid bits here and there
Dori Dori
Car: Cars of course
They are the same, 100%. The only problem I see with you doing this is that you're gonna end up using older bushings in the arms unless you replace them while the subframe's out. Maybe I'm misunderstanding you and you're planning on doing this with new parts.
240sxGT
98 Nissan Maxima SE
93 Subaru Imprezza
Thanks guys, yeah everything will be replaced got all new SPL suspension to go on there
