cencalal »
https://forums.nicoclub.com/cencalal-u266922.html
Sat Sep 17, 2016 1:20 pm
I'm new to this forum because in the twenty years I've had this car, the only problems I've had were a bad starter and two fuel injectors. This is a '91 coupe automatic, base model with AC. 141K miles. I recently changed a fuel injector and didn't get the lower o-ring seated correctly, so when I tried to start it, gasoline flooded the cylinder and I ended up with a couple of quarts of gas in the oil pan. The level on the dipstick was about two inches above full mark. Mistakenly left it sitting for a week till I could get back to it, drained the oil into several pans and left them outside to evaporate the gas, so that I could safely recycle the oil. When I emptied the pans, there was a bit of sludge in the bottom of each.
Now I have an oil leak from what looks to be the front crank seal - oil is dripping from that pulley when I park it, and it leaks about a 4"-6" circle right away, and then stops. It doesn't seem to be leaking much when it's running, but that may be because I'm running a Krankvent valve, and the crankcase vacuum is preventing leaks. I've been driving the car daily for three weeks since changing the oil and filter, and for a few days the leak stopped entirely, but now it's back.
Did the gas in the oil ruin my seals, maybe by removing some gunk that was helping them seal? Am I totally screwed? Magic remedies in a bottle? Change to "high mileage" oil and pray?
Thanks
Alan
