matt4pl »
https://forums.nicoclub.com/matt4pl-u4587.html
Fri Jul 18, 2003 2:08 pm
ok, so i went to get my oil change, on the way home, my car started going goofy, the rpm's would jump all over the place while i tried to accel, or after shifting, so i went back to the mechanic, they said its definately misfiring, i changed my plugs to bosch spark 4's a week ago, i added engine cleaner to my oil a few days ago, and i also added fuel system cleaner to my tank today, at about half full, then filled up afterwards, so im assuming its an injector? how do i tell if its bad? i've been told to use a multimeter, and how can i tell if a used injector is good withough being able to test it in a running car? thanks in advance
P.S. my car's got 123k on it, and i doubt its had an injector job
