240 lugs
clockwork
How much do you torque 240 lugs? I have alloy Konig 17's. Called some tire shops and got different answers. Anyone know?
Thanks,Clockwork
BabyboyDeLa240
Car: Cars, Girls, and Money
Go to a good trusted most respected Tire/Wheel Shop and stick with what they have or use.
silverPS13
With the factory alloys the FSM states 72-87ftlbs all around, should be the same with the Konig's
Exar-Kun
Car: 2005 350Z
yes, torque goes by car, like tire inflation, not by wheel or tire, etc...
87 ft/lb would be the max to run, unless you use NISMO studs...-chet
super_hicas
oh, i always did 65lbs. whatevers. same thing.
silverPS13
Not really the same thing if your wheel falls off...your ***, I would torque it to the proper specs. Lug nuts arent one thing you go half-assed on
clockwork
Thanks guys, i torqued them to 85 ft. lbs. - which is what a good tire place said that asked for my car year/model. Another place i called said 100 ft. lbs. for any alloy wheel - so i guess i won't go there, ever
Clockwork
kami240sx
Car: 1995 240sx
my wheel place also mentioned to retorque the lugs after 50 miles or so to make sure nothing's gonna fall off. better safe than sorry
drifter
Car: Drifting, cars, etc.
NOOB question, but...
How can you tell how many lbs you've torqued the lug nuts?
Holisticbeatz
drifter wrote:NOOB question, but...
With a torque wrench.
