240 KA trans on a QR25... would it work???
Including IL, IN, KY, TN, MI, and OH
spec-bre
Car: 2002 Nissan Sentra SE-R Spec-v
I had seen a discussion another forum in regards to bolting a 240 KA trans up to a QR25DE and dropping it in a 510. can't seem to find the thread or verdict and I have a QR block in the garage if someone in the central Indiana area has a spare/junk KA 240 trans lying around to find out.?
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
I haven't seen anything about it, but it seems somewhat feasible.
spec-bre
There has to be a KA trans sitting in someones garage... lol! I have two QR blocks at the moment.
nametakennow
Car: '06 MINI Cooper S
Seems like it'd be easier to use a Frontier trans and block since it's RWD, maybe swap out the internals and gears of an SE-R for better performance.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Weird.... I was telling my buddy today we should QR swap his 240... Would be cool if it does infact line up. But what clutch?
spec-bre
nametakennow wrote:Seems like it'd be easier to use a Frontier trans and block since it's RWD, maybe swap out the internals and gears of an SE-R for better performance.
Yes the Frontier trans is a definite option but if the KA trans would bolt up no need to swap gears and such. I think a 6 speed in the 510 would be a waist of time and gear. It's a 2,000 lbs car so good mpg's are easy to achieve.
nametakennow
By that same token, the gearing on a 4cyl truck isn't so far removed from a car as to make it necessary to swap the gears, that was just a suggestion. In fact, I don't think the KA trans differs much at all between the 240s and Frontiers of correlating years. So while the KA trans may bolt up, a QR trans will bolt up. Either option may require the use of a RWD QR block.
spec-bre
Not my car but here is the project...http://s257.photobucket.com/al...lo510/
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Is that a FWD engine in the pics?
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
Looks like it to me.
spec-bre
OutToWinPAHC wrote:Is that a FWD engine in the pics?
No. I believe it's a Frontier rwd QR25. Look at the starter location. Opposite side of the engine.
Dropoff510
Car: 1971 datsun 510 with sentra qr25
Hey I'm doing a sentra Ser swap into a datsun 510. I have some videos of progress on YouTube. Here's the links. http://www.youtube.com/watch?v=8k2-IUcW ... ata_player
http://www.youtube.com/watch?v=uFzXqTuk ... ata_player
http://www.youtube.com/watch?v=VkgE_dsU ... ata_player
But so to answer the question. The QR uses a bigger flywheel it barley fit in the 300zx transmission. I had to grind away a little inside transmission just to be safe. And you need a frontier flywheel so you can put starter in correct rwd setup. There's pics in the videos of it. Hope that helps :)
Qr86
Car: ae86 with spec v qr25de and frontier trans
I'm thinking about doing the same swap as you man. I stumbled across your threads and like the idea, plus I haven't seen anyone do it with an ae86. I want to be the first or atleast be the first one I know if with it. I cant personal message you cause I'm a new member so pm me I have some questions about the swap and stuff.
Return to “Central Region”
