240 ka rb swap cluster problem
OhSnapS14
okay so its an original ka auto but has been swapped with a rb20det in a s14. I was wondering why the cluster doesn't read right, everything seems to be doubled. so if im doing 40 on it im actually doing 20 and so fourth. any idea as to what may be going on? Is this because its a cluster outta a 4 cyl running on a 6cyl car?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Yes that's excactly why. There is a converter you can get to fix it or you can swap in a j30 speedo.
OhSnapS14
Ah i see, i was hoping it would be as simple as resetting it. but i have to go another route i will. Thanks for the help! :bigthumb:
robhuller
Car: 1997 Nissan 240sx SE
I read somewhere that the tach is as simple as adjusting some set screw on the back of the cluster? Not sure but may lead to the answers?
zmannz
Car: 89 s13 coupe- track car
92 s13 coupe- dd
You can modify the ka cluster but it won't be very accurate.
zmannz
92 s13 coupe- dd
