240 jumps revs then dies
240noobbb
Car: 93 nissan 240sx
I bought a 240 and had to replace them engine in it. I put in a ka24de.
my problem is my car will start then it jumps revs to 2500-3000 and then dies. I thought it was the MAF but when I replaced it nothing. right now the egr is open Bc I took off the egr valve but I have ordered a block off plate. please help thanks
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
You need to block off the EGR hole, that's most likely your issue.
Alisaihin
Car: Got two, see signature! :3
2_Liter_Turbo wrote:You need to block off the EGR hole, that's most likely your issue.
Seconded. Having the EGR open is basically allowing the engine to suck in a TON of unmetered, unfiltered air straight into the intake manifold.
First off, this air is something the engine is not anticipating, as the MAF is what senses how much air the engine is getting. This sends a signal to the ECU to let it know how much fuel it needs to spray in, in layman's terms.
Trying to run an engine like that will foul it and make it run lean as f*** (Because there's so much more air than fuel)...though, as we can see, if it even runs at all, because there's likely too much air and not enough actual combustion.
