So my last picture IS correct ?locoluna825 wrote:
And as for my MAF
No, its just on the other side of the intake filter.
because the way my car is in MY pictures...
your picture would be like this..
right?
Modified by Schmitz_7 at 4:45 AM 2/23/2009
#1 is top forward. If you want you can confirm which one is #1 by turning the engine manually until the tdc mark on the crankshaft is at the timing mark. The distributor should point to #1 plug contact.Schmitz_7 wrote:
The above photo wiring appears to be 3-4-2-1. Incorrect.
This is correct.
This is not.
yea the way you got it flipped is right but turn the distributor cap the same way so the little screw holes in the drawn picture match up with the screw in the real picture above.Schmitz_7 wrote:
And as for my MAF
right?
