Crunkrich »
https://forums.nicoclub.com/crunkrich-u36411.html
Tue Nov 28, 2006 7:55 pm
The stock tubing has the hole on the bottom under the first bend from the throttle body for a resonator. It should be about an inch in inside diameter. Just take a coke bottle cap and plug that hose, then connect the other three where they go.
The resonator down there isn't necessary, no problems will come up from plugging it, all it is an air reservoir.
