Acecool »
https://forums.nicoclub.com/acecool-u46759.html
Thu Sep 14, 2006 2:56 pm
Did you check the ecu twice?
The first time you check it, it shows any stored error codes, the second (you turn engine key to off, then back to on, initialize and then it should show new ones)
I had that problem, except it got stuck around 2500 rpm..
Start the car, and take each injector plug off seperatly, one at a time.. Does that change the idle or cause it to stall?
Notice no difference? That fuel injector may be bad..
When was the last time the fuel filter was changed?
