240 headlight problems
240sxPro
Car: 240sx
im sure this has been asked before, but does anyone know why the headlights wont go down. its not a fuse, and im not good at electrical work. could it be the button or a wiring issue?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Check the plugs at the motors and make sure they're plugged in.
The only two possibilites it could be for the down circuit not working on both is a bad headlamp timing unit (doubtful) or a bad Retract Relay 3 (likely). The relay is located in the driver side relay box. I can't remember it's exact location, but it's a black relay labelled H/L Retract or something like that. There will be two other H/L relays next to it, but they should be identical to each other save a Left and Right designation.
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
ive got an 93 s13 and when i put the headlights down only one goes down then about 30 seconds later the other one goes down. same for when i put them up just reversed. its not that big of a deal at least they work!
CMG
Car: 1989 240sx Hatch w/ Redtop
If it's not the above mentioned items, check your wiring, could be corroded.
