onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Thu Sep 30, 2004 7:40 am
You can always reverse pivot controller (used for sleepy eye in the down position). all you have to do is tap into the headlamp up wire instead of headlamp down wire.
Like the other guys said, do search for sleepy eye, then you can modify from there.
You can also getto it and disconnect the motor, manually rotate it to where you want, and always be sleepy .
