Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Jan 13, 2014 1:14 pm
Check for a harness rub through in the hatch area, then. Could be that you're getting a short in the system that's just bleeding back to the chassis when you depress the brake pedal. Also, and this might come across as really simple, make sure the stop lamp switch on the brake pedal is plugged in and getting a 12v supply. If you don't find a rub through in the harness, you can eliminate the switch by jumping the plug. If you get brake lights, replace the switch.
