reallysorry »
https://forums.nicoclub.com/reallysorry-u101250.html
Tue Nov 04, 2008 12:18 pm
So i have a sohc ka. Everytime I start up the car it'll start and run for maybe a few seconds. Then the rpm's will drop down to 0 and the whole car will die out. The motor will start to shake as it goes down to 0. I can only keep the car running by reving the motor, but even then it'll try to die as I give it a steady foot of throttle. I checked all the plug wires for resistance and those were fine. Checked the spark plugs and cylinder #2 plug's electrode at the end of the plug burned off. I replaced those and it still doesn't run. It's misfiring right now and it's not going so great. I don't know if my timing could affect this and would do this or if there isn't sufficient enough of fuel pressure going into the cylinders. Maybe the distributor rotor is bad or maybe the fuel injectors? I'm trying to look into it but everytime I do something it doesn't get me anywhere. Anybody have any suggestions to what it might be?
