maniacman9558 »
https://forums.nicoclub.com/maniacman9558-u139771.html
Thu Jan 14, 2010 6:17 am
i have a 93 240 with stock ka and it stared off just as an every now and then cut out and kept getting worse now you can barly drive the car. it hasent actually died yet just acts like its running out of fuel but just filled it up and still does it. and i replaced pretty much my hole ignition system about 2 months ago.and the problem started about 3 weeks ago. and the weird part is the car runs fine for about 20mins then it gets worse the more you drive it. and just replaced my fuel pump not to long ago could it be going bad already? or O2 sensor issue so somthing? im stumped i did cheak my injectors and one one at 20ohms and the rest at 11-13 could that be the prob?
