turtl631 wrote:Wow, scary. Hot coolant and randomly arcing wires are always scary as crap when you're not expecting them.
On a side note, is this a built block? 18 psi with only .2 degree retard/pound sounds quite risky on the stock block..but im sure its a blast to drive
Well at the time I was doing the tuning, I was running the AF mix fairly rich, the leanest it got was 11.8/1 My target is 12.5-12.7 or so. Thats where the most power can be made so long as your temps are kept down. The reason I'm running only .2 or so per lb is that I normally wouldn't even worry about timing retard until 8 psi. But the BTM starts retard as soon as it see's boost. So I figured I'd have a few degree's to work with since I'm losing timing earlier then I want to.
I originally started with 1 degree per lb, until I got the AF's down to 11's accross the board on boost. Then I turned the knob down to .5 per lb and re-did the test, no knock, no sputter and alot more power. After I had the AF's steady at 11.5-11.8 I turned the knob back a touch further to see if I'd start to get any knock or feel any detonation. I don't recommend this unless you've already blown up a few motors and know exactly what your looking for. Which I've done...more times then I'd like to remember.
Anyway, once I get her running, I'll save the daily driver map as setting 1, then tune her for alcohol on setting 2. With the alky, I should easily be able to run no retard and the same amount of boost.
Actually, I was thinking about a dual injection setup. a fine one stage water injection nozzle, starting spray at 8 psi. This is simply to cool the intake temps and EGT's down for timing. I measured the injection of water on my Skyline and with just a fine mist I was dropping 200-230 degree's in my EGT's. Then I add the variable alky injection across the board on boost for octane and fuel enrichment, allowing me to run more boost with no timing issues.
Baring in mind I'm not looking to excede 390 ft lbs of torque. I figure I'll hover at the breaking point till I get some new rods and pistons.
WD
