240 clutch in a d21?
240man91
Car: 1991 nissan 240sx se hicas
Hey guys i am wanting to know if i can put a 240sx clutch in a 90 d21 it has a dohc ka and is 4x2.
WDRacing
That's a good question. Let me get some help from an expert.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
A '90 with DOHC? Was it swapped? All 4 banger D21 trucks were SOHC KA24E engines and didn't go DOHC until the release of the D22 Frontier with the KA24DE. The truck clutch disk is actually a bigger at 240mm.
240man91
Yes it is being swaped right now. But i have a stage three f1 clutch i bought for my 240 but didnt use because i didnt think it would hold the power from 20psi. So i just have now and i am doi g this swap, and if it will fit i want to use it.
WDRacing
Where is the KA24DE from? If it's out of a 240 then use the 240 flywheel and that F1 clutch. I doubt the stock KA is going to over power the clutch.
240man91
No it wont over power the f1 i just want to make sure it would work with the trans
