nisssan-drive wrote:haha yeah noticed the know!
Any way thank you now when i go out to take my manifold off I will have a couple other things to look at. For the "air injection crap" on the header i am not sure ill have to go check.
Yeah its too dark cant just go check the stock heat shield is covering the header, but i dont think theres any thing like that on my car.
Modified by nisssan-drive at 7:54 PM 1/13/2008
If your car is mostly stock, Im betting you DO in fact have this pesky little box. Here is a link that will be rather helpful. -->>
zerothread/253879
Its not really under the heat shield, although it comes from part of the exhaust system...Looking from the front of the car, stand directly in front of the airbox or air filter and look for a rubber hose that connects to the intake AFTER the filter, but BEFORE the MAF sensor. Follow that tube straight back (towards the steering wheel), it goes to a black box (see pic in link) that should be slightly higher than, but almost directly across from your header/heat shield. That black box may be your issue. My 93 was doing the hesitation and bogging down thing after warm up too. I just cut that hose and plugged the half of it leading to my intake with a huge bolt from Home Depot (5/8 inch I believe)...left the hose coming FROM the black box open to the air. Car has pulled way better and stopped bogging down on me since that very day (you can kinda smell exhaust after a nice WOT pull though). But, I would certainly change your fuel filter too (get the one for the 300zx as people say it fits but is less restrictive) and make sure if you do pull your spark plugs to check the gap (stock is .42 - .44 I believe). Check your wires for holes like the other guy mentioned while your there! Oh, and I'm not knocking you, but correct spelling is helpful, cause when I first read your post I was like "Huh??" Had to go back and re-read it, lol. Good luck, bro, don't get discouraged, this sounds easy to fix once you find the issue...
