Arsine Lupin »
https://forums.nicoclub.com/arsine-lupin-u47147.html
Tue Oct 03, 2006 9:53 pm
I was just looking for some help with my 89 240 coupe could you guys help me out I have no idea what to do about the first and need some advice on the others. 1. I changed this little valve(which the service manual calls the pulsed secondary air injection solenoid valve) because my mechanic said it might be bad due to the fact that when I disconnect it, the check engine light turns on but the car runs great and when I reconnect it the check engine light turns off but the car runs like crap it feels like its going to stall when I accelerate, and the engine runs really rough when I'm driving at a constant speed.
2. My air conditioning will only work up to the third speed setting after that it turns off and no more cold air comes out
3. And last but not least I recently swapped my cluster to analog after my HUD went out completely but the speed is still weird the needle will occasionally drop to zero and when it does work it is from my estimate 10 MPH faster(did the same thing with the HUD)
Modified by Arsine Lupin at 3:05 PM 10/6/2006
