DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Sun Nov 05, 2006 2:34 pm
well if youre skeptical, i welcome you to be, as you should.
the only way to tell if this is true, and your KA just isnt in horse**** shape, is to go out, and unplug the CTS.
im not telling you to buy anything, im just saying, because ive had this problem, you can go out and unplug your CTS, drive it around, let it warm all the way up to temp.
if your car isnt really slow, except a burst of power at around 5500 rpms, then your CTS is probably fine.
or you can spec it with a multimeter
im not saying its telling the ecu anything, im saying its behaving as an out of spec sesnor, and the ecu switches fuel maps. a guy on zilvia or FA had a dyno showing the losses from having / unplugging the CTS.
and i dont think the scantool would fine the cts, and the cts is different than the temp gauges sensor, they sit right next to each other.
so i pointed out a very common problem, that i too have had experience with, and its very easy to test out/ cheap to replace/ easily searchable.... so you really cant complain
