Shift_Kouki wrote:I'm not sure what you've read in your searches, but wouldn't whats said in a lot of the cam threads be applicable to just about any type of cam swap?
Why are you dropping in smaller cams? I mean you're at 240/248 stock... I can kind of see dropping in an S14 exhaust cam as exhaust to help with low end a tiny tiny bit, but my question is why? You have one of the better set ups around as it is.
I think the big thing is to double check the degree's per gear teeth. But I'm a bit confused as to what your getting at there...
Also, about the big post count people... Tloof only had 70-80 posts for a VERY long time.
Thanks, but we've read the two threads you've mentioned and more... Apparently not all the swaps are the same. Using the four teeth mothod doesn't work for this swap, it still doesn't line up right.
As to y do this swap, his car is an auto and his 248 cracked beyond repair. I happened to have some s14 cams laying around that I bought for my 248/232 swap, so I gave him the intake cam that I wasn't using. Per the 'My Comments on blah blah swap" 240/232 should be really good for the auto car...
Modified by simmode1 at 5:17 PM 12/9/2007
