24" wheels on a qx56 4wd
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
gmotoring
Car: 2004 E500, 2007 QX56
I'm new to this forum. Has anyone installed 24's on their QX56? if yes, please advise the Offset used and tire size and if you had any issuesof rubbing? I guess I am deciding between 22's or 24's
radride
Car: 93 RX7, 07 Versa
I'm going through the same situation. I'm scared that 22" will too small for the QX 56. I just don't know.
R.K.
lowincQX26
Car: 05 Nissan Armada
gmotoring wrote:I'm new to this forum. Has anyone installed 24's on their QX56? if yes, please advise the Offset used and tire size and if you had any issuesof rubbing? I guess I am deciding between 22's or 24's
24's with tire size 285-40-24 is a good comination rides like factory perfert look for the big suv. If you need wheels or info please give us a call 817-477-3575
lowincQX26
radride wrote:I'm going through the same situation. I'm scared that 22" will too small for the QX 56. I just don't know.
R.K.
go with at least 24's , 22's are very small for the big suv trust me. Ive sold a lot of 22's to the armadas and they all come back to get 24's let me know if you intrested in buy some wheels 817-477-3575
radride
Do you have a toll free number? Do you have a website? Which wheels do you carry? Are you willing to ship to Canada? If so how much would 24's with 305/35/24's be to ship to Edmonton, Alberta Canada with postal code T6R 0C2?
R.K.
gmotoring
thanks LowincQX26What Offset would you use, +15mm or +18mm on the 24" wheels?
lowincQX26
gmotoring wrote:thanks LowincQX26What Offset would you use, +15mm or +18mm on the 24" wheels?
stay with 18 or higher i say 18
gmotoring
stay with 18 or higher i say 18[/QUOTE]
Thanks LowincQX26
I am looking to get these wheels http://www.bossmotorsports.com...d=355
They only have 12mm or 30mm, do you think 30mm is just to tucked in for the aggressive look.
lowincQX26
Thanks LowincQX26
[/QUOTE]
those wheels look good they should be fine make sure you ask them if its going to fit and make sure you get the 305-35-24
DJGAINSBOND
gmotoring
That is Nice with the 26"
I just bought my rims they are 24" x 10 with a +12mm offset. Hope it fits with no rubbing.
gmotoring
Installed the 24" rims this week-end with 285/40/24 tires (almost a 33" tall tire) , the rims are 24x10 with 12mm offset. It is perfect no rubbing at all.
with the 40 series tire i have plenty of side wall so I will not worry as much about rough road and pot holes . because I have 30 series tires on my Benz and the rims get really hammered and become out of round after time.
gabby
how important is the off set. i'm trying to get the Zenetti 24in blade , but the offset comes in 10 or 35http://www.streetdreams.org/wh...24/10
gmotoring
gabby wrote:how important is the off set. i'm trying to get the Zenetti 24in blade , but the offset comes in 10 or 35http://www.streetdreams.org/wh...24/10
Off set is the distance from its hub mounting surface to the centerline of the wheel. The assumption is the numbers on the site is "+" offset. Thus, the lower the number the more aggreasive or more the wheel will have a deep dish. the higher the number the more the wheel will be tucked in.
I like my wheels flush with the fenders so I like +10 or +12 offset, +30 is going to give you more of the factory look (more tucked in look vs the wider stance.
Now with 305/35/24 running the 10mm offset you might rubb the inner fender moulding during turns.
gabby
So would the 35's be too much ? how about the 285/40/24 with the 10 off set or the 35 offset ?
gmotoring
gabby wrote:So would the 35's be too much ? how about the 285/40/24 with the 10 off set or the 35 offset ?
I am running the 285/40/24 with 12 offset, it fits perfect. going to 10, that is only 2mm differeence which is .08"(5/64"), I would think it would work just fine, and on extreme turns like a U-turn you might get a little rub inside the wheel well, which you will not even know it.
Plus the 285/40/24 are about $20 cheaper per tire too.
gabby
What about the 35offset with the 40's? What kind of look would that give me. Thanks for your help
DJGAINSBOND wrote:
Gorgeous! We need more pics!!!
gmotoring
Going 35 vs 10 offset would put your wheels 1inch from the flush line of your fenders. It will look alright, it will look like the stock set up when view straight on or from behind.
gabby
Anybody have a suggestion on tires? if I go with a 285/40VR24 my only choice is the Toyo ProxesST . If I go with 305/35VR24 my brand choices are:Pirelli Scorpion Zero Asimmetrico ,Lexani Roadian HP ,Kumho Ecsta STX , Falken STZ 04, Cooper Zeon XST , Hankook Ventus ST , Nitto NT 420 S, Yokohama Parada SpecX, and Nexon Roadian HP
simplexveritas
just throwing it out there, but i feel everyone on the 22s possibly being too much... but 24s? seems just too big.
JamesBG35
Car: 2005 G35C 6MT
I've had my 22's for 3 years now. I guess it depends on the wheel but these are the right size for me...
gabby
my 08 with 24's and the 285/40/24 tires work great. Thanks "gmotoring" for the advice
gmotoring
GabbyNice ride, I am glad you went with 24", 22" looks good on tahoe's but just a littrle too small on the huge QX56.
BTW, where do you host pics, I would like to post the pics on my wife's QX with 24"
Gmotoring
gabby
gmotoring wrote:GabbyNice ride, I am glad you went with 24", 22" looks good on tahoe's but just a littrle too small on the huge QX56.
Gmotoring
The 20's that come on it stock are pretty tall, but those 24's are a nice touch and the ride is still very smooth.photobucket.com
gmotoring
Here is my wife's Ride with 24" rims and 285/40/24 tires
Modified by gmotoring at 9:55 AM 8/28/2007
Modified by gmotoring at 9:56 AM 8/28/2007
gabby
gmotoring wrote:Here is my wife's Ride with 24" rims and 285/40/24 tires
that's a great look
MIKE DEGUZMAN
24 is perfect for qx's n armada's
duffman1278
Car: 89 240sx Hatch, the wildcats!
Wow, they look REALLY niiice
ssal428
Car: 2008 Nissan Armada
I'm new to this site. I recently purchased an 08 Armada LE about 6 months ago and I just ordered 24" inch Lexani wheels for it. I was curious about what brand of tires to go with for a 285 40 24 size tires. There isn't that many choices out there. What tire did you go with? I'm leaning toward the Toyo proxe ST. Let me know what you think. Thanks.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
