24 led turn signal led bulb.. need resistor?
Heels1010
http://cgi.ebay.com/ebaymotors...A1318
it states that it draws low amps at only 1.8 watts. could i just plug and play these in my turn signals or would i have to mess with a resistor? thanks
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
I believe someone on here tired that over a year ago, and they got the fast flashing blinker... you'd need to find out the correct impedence and add a resistor that gets you there to avoid the "fast blinker".. and I'm sorry, I don't know what resistor you'd need.. hopefully someone else will chime in!
Heels1010
is the fast blinker bad for the car or look dumb? i've seen it on other cars and thought it was different.
legend_217
Car: 08 Altima Coupe 3.5 black
When you install LED bulb for signal, you must have a resistor otherwise your bulb won't work.
