ahhbeebee »
https://forums.nicoclub.com/ahhbeebee-u96922.html
Tue Sep 01, 2009 7:15 am
Just went to talk to my dealer also about the Schedule 1, 24000km service and they quoted about the same price ~$350. Two big items, oil change and in-cabin air filter can be done on your own and should save you $180 ($50 for oil change and $130 for in-cabin air filter).
They gave me a print out of what is done, I'll list some here.Engine oil & filterLube locks, latches, hinges, steering stopsRotate tiresService rear brakes.Inspect for fluid leaksAdjust engine drive beltsTest brake & clutch fluidInspect engine air filter, engine coolant and power steering fluid & top-up, tires and tire pressure, fill washer fluid and inspect blades, inspect CV boots, shocks/struts, steering gear and linkage, ball joints, lights, CVT fluid, axle & suspension, battery & terminals, brake pads, rotors, drums & linings, exhaust system, drive shafts & U joints, rear differential oil, transfer case oil, rear differ breather, reset maintenance interval computer
and lastly road test vehicle.
Nothing extraordinary, and largely doable on your own. I'll probably have them do all the inspecting and tire rotation for $150 so I can keep a record they have looked at it. Probably do this annually or every 15 months.
